Activity Forums Adobe After Effects Expressions Linking Transparency to Position?
  • Linking Transparency to Position?
    Posted by Robert Røbke on November 28, 2017 at 3:27 pm
    can somebody explain me how i can link a shape layers transparency in dependency to its position? So if the layer moves up in y it should be less transparent as higher it gets?
    Hope you understand what i mean. ????
    Thanks in advance.
    Rob
    David Cabestany replied 8 years, 9 months ago 3 Members · 2 Replies
  • Dan Ebberts
    November 28, 2017 at 4:58 pm
    It would help if you were more specific–numbers, range, etc.
    Dan
  • David Cabestany
    November 28, 2017 at 5:33 pm
    You need a linear expression, like the one below.
    You need to adjust it to your actual y position parameters though.
    t=transform.position[1]
    linear(t,832,50,0,100)
