Activity Forums Adobe After Effects Expressions linking to only – x, y or z .
  • linking to only – x, y or z .
    Posted by Richie Tovell on December 26, 2008 at 3:01 pm
    Hi, appologies I know nothing about expressions and up until now have not needed to use them, but now I’m stuck can anyone help?
    I want to link the output of trapcode soundkeys to just the X position of a layer. I drag the pickwhip from the position expresion controls to the output of Trapcode soundkeys and firstly the layers shoots off to the right then I get no movement at all. How do I achieve what I want to do, when I drag the pickwhip from the layer position to soundkeys, this expression appears by the position controls
    temp = thisComp.layer(“Black Solid 9”).effect(“Sound Keys”)(“Output 1”);
    [temp, temp, temp]
    I’m sure I need to edit this expresion to something else, I solely want Soundkeys to effect the X position.
    I also need to repeat this proccess for some of the other “linked” 3x perameters like for example, for a layers width only.
    Can anyone help, I should think this is as far as my needs go for expresions, so if someone could help me out on this one I should be able to get by with the rest of after effects ok. . . . I hope 🙂
    Richie Tovell replied 17 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 26, 2008 at 6:09 pm
    Like this:
    [temp, value[1], value[2]]
    Or, if you just want the sound to offset the x position, like this:
    value + [temp, 0, 0]
    Dan
  • Richie Tovell
    December 26, 2008 at 6:43 pm
    Coooool Dan 🙂
    Thanks thats done the trick.
    Richie.
