Activity Forums Adobe After Effects Expressions Linking the Scale to Position with Easy Ease and Limitations
  • Linking the Scale to Position with Easy Ease and Limitations
    Posted by George Henderson on August 12, 2019 at 4:59 pm
    Hello,
    I have a keyframed object moving from left to right on the X axis with easy ease applied to them.
    I’m trying to scale up the object as it goes from point A to B, but I want it to match the position’s easing speed and scale up to no more than 15%.
    Any help would be greatly appreciated!
    p=transform.position[0];
    x=transform.scale[0];
    y=transform.scale[1];
    [x,y];
    Dan Ebberts replied 7 years ago 2 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    August 12, 2019 at 9:03 pm
    Is your position animation 2 keyframes? If so, something like this might work:
    p = transform.position;
    s = linear(p.value[0],p.key(1).value[0],p.key(2).value[0],0,15);
    [s,s]
    Dan
  • George Henderson
    August 13, 2019 at 3:44 am
    That’s perfect, it’s doing exactly what I was hoping for. Thank you Dan!
    Is there anyway to avoid getting errors when there are no keyframes on the layer?
  • Dan Ebberts
    August 13, 2019 at 4:48 am
    I haven’t tested it, but something like this:
    if (p.numKeys > 1){
    [s,s];
    }else{
    value;
    Dan
  • George Henderson
    August 13, 2019 at 7:57 pm
    Hi Dan,
    Thank you once again! The code works when it’s used outright, but I I’m having trouble implementing it into the script that I’m working on.
    Without the no keyframe script, it reads the following:
    Y=thisComp.layer(“Y2 – L”).transform.yPosition; //position of the animated layer (2 keyframes, key1=720 & key2=320)
    N=Y.numKeys;
    K = value+(Y-Y.valueAtTime(0))/2;
    var YY=Y.key(N).value;
    if(YY<360){[K];} else {value;}
    when I add the condition that there may be no keyframes, the script above fails to function. However, I am able to delete the keyframes without receiving any errors; so the first bit is working. I just don’t know how to write: if (keyframes don’t exist AND any value smaller than 360) then do {K}.
    N=Y.numKeys;
    K = value+(Y-Y.valueAtTime(0))/2);
    if(N > 1&YY<360) {var YY=Y.key(N).value;[K];} else {value;}
    Any ideas how to get the two conditions to work together? Thanks!
  • Dan Ebberts
    August 13, 2019 at 8:43 pm
    I haven’t tested this, but I think it would look like this:
    Y=thisComp.layer("Y2 - L").transform.yPosition;
    N=Y.numKeys;
    val = value;
    if(N > 1){
    YY=Y.key(N).value;
    if (YY<360) val = K;
    val
    Dan
  • George Henderson
    August 13, 2019 at 10:49 pm
    Dan, you had the answers to every single one of my questions. I’m truly grateful for all your assistance.
    Thank you!
  • George Henderson
    August 14, 2019 at 10:01 pm
    Hello,
    I have been trying to get this to work for the last several hours but to no avail. Could you please let me know where the issue is?
    It refuses to run the else statement when the value is => 1280.
    Error at line 1… Undefined value used in expression (could be an out of range array subscript?)!!!
    PX=thisComp.layer("X1 - R").transform.xPosition;
    PN = PX.numKeys;
    val=value;
    S=33.33
    if (PN > 1) {PXK=linear(PX.value,PX.key(1).value,PX.key(2).value,100,33.33333); PNS=PX.key(PN).value; if(PNS &lt; 1280) val=[PXK,PXK];}
    else
    if(PN > 1) {PNS=PX.key(PN).value; if(PNS => 1280) val=[S,S];}
  • Dan Ebberts
    August 14, 2019 at 10:45 pm
    It looks like you have:
    if (PN > 1){
    followed by :
    }else if (PN > 1){
    so it will never get to the 2nd one.
    Dan
