Activity › Forums › Adobe After Effects Expressions › Linking Scale to Position
  • Linking Scale to Position
    Posted by Donovan Peterson on August 7, 2022 at 12:39 am
    Hello! My apologies if this questions has been asked already. I made a simple lower third template for a client and they would like me to add a few things to the template. In this template I have a MASTER_CTRL that allows them to make the tab length bigger or smaller along the x-axis. To achieve this, I did an animation on the scale transform from 0 to 100 on the x-axis on my shape layer, then parented it to a null and did an expression linking that nulls scale to my Master Control. I want to make the scale control the position of these newly added elements at the end of the tab. Is there an expression that might work?
    Adam Greenberg replied 4 years, 1 month ago 2 Members · 1 Reply
  • Adam Greenberg
    August 16, 2022 at 1:49 pm
    it sounds possible, but I think no one answered yet because its still not clear what you want to do exactly
