Activity Forums Adobe After Effects Expressions Linking rotational value correctly to a compass graphic
  • Linking rotational value correctly to a compass graphic
    Posted by Scott Green on December 2, 2019 at 12:45 pm
    I’ve been racking my brains trying to figure out how to correctly link a number value to a rotating compass graphic (using a basic wiggle) so that the values are between 0° and 360° (or 359° and then it changes to 0 if it’s 360°) rather than using minus values.
    Can anyone help?
    21° is correct.
    -30° is incorrect – this should be 330°.
    Project file:
    13937_compass.aep.zip
    -thisComp.layer("Dial").transform.rotation[0].toFixed(0)+"°"
    Dan Ebberts
    replied 6 years, 9 months ago
    2 Members · 5 Replies
  • Dan Ebberts
    December 2, 2019 at 4:01 pm
    You could change your rotation wiggle() expression to:
    w = wiggle(0.2,60);
    if (w < 0) w += 360;
    w
    and remove the “-” from your text expression.
    Dan
  • Scott Green
    December 10, 2019 at 7:51 am
    Sorry for the late reply Dan, the notification ended up in my spam folder.
    Thanks for the info, but I’m not quite getting the result I was hoping for.
    I think that the solution might be to try and link the Source Text property to the 2nd value of the Rotation Property, but to ignore the “1x” value and the “-” value.
    For example…
    …ignore “0x” and ignore “” to give 15°.
    …ignore “0x” and ignore “” to give 359°.
    …ignore “-1x” to give .
    …ignore “-1x” to give 30°.
    Does that make more sense?
    Would that be possible?
    The wiggle was used just to test it out. I’ll probably be keyframing these values manually but with a bit of wiggle added.
    Many thanks.
  • Dan Ebberts
    December 10, 2019 at 8:01 am
    Maybe like this then:
    w = wiggle(0.2,60);
    w %= 360;
    w += (w < 0) ? 360 : 0;
    Dan
  • Scott Green
    December 10, 2019 at 8:06 am
    Sorry, that doesn’t work either.
    Motion Videos UK – We are creative video designers who bring pleasure, meaning and beauty to our small world through film, motion graphics and animation.
  • Dan Ebberts
    December 10, 2019 at 5:01 pm
    I think you just need to get rid of the “-” operator at the beginning of your text expression.
    Dan
