Activity Forums Adobe After Effects Expressions Linking range – Height Scale to Y Position
  • Linking range – Height Scale to Y Position
    Posted by Saber Na on August 7, 2017 at 7:04 pm
    Hi, I’m trying to make the white triangle’s height to follow the yellow triangle’s Y position. I’ve tried this script but it is not working. Any help would be greatly appreciated.
    temp = thisComp.layer("Shape Laye 2").transform.position[1]*-100/350+174;
    [transform.scale[0], temp]
    Andrei Popa replied 9 years ago 2 Members · 3 Replies
  • Andrei Popa
    August 8, 2017 at 9:46 am
    I made it this way. On the anchor property of your size-modifiyng layer add the expression
    temp = thisLayer.sourceRectAtTime(time,false).height/2;
    [value[0],temp]
    and on the size position (Rectangle 1>Rectangle path 1> Size) addd the expression
    temp = (thisComp.layer("Shape Laye 2").transform.position[1]*-1 + height)/2;
    [value[0], temp]
    replace “height” with the starting coordinates of your layers, or align the size-modifiyng layer to the bottom of the composition. I added an image for easier understanding.
    Andrei
  • Saber Na
    August 8, 2017 at 7:10 pm
    Wow! Thank you very much Andrei, it works exactly the way it should!
  • Andrei Popa
    August 9, 2017 at 9:08 am
    Glad i could help!
    Andrei
