Activity Forums Adobe After Effects Expressions Linking paths of Shape object.
  • Linking paths of Shape object.
    Posted by Andrew Ross on June 18, 2015 at 3:11 pm
    Hi there.
    I’m on a job where there will be a large output. To make changes easier down the line, is there a way of linking the path of one shape object to the path of another shape object so that I would only need to alter the path of one of the shape objects and it will alter the rest.
    Thanks in advance
    Andy
    Andrew Ross replied 11 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 18, 2015 at 4:46 pm
    You can just use the pick whip to connect one path to the other. You’ll end up with something like this:
    thisComp.layer(“Shape Layer 1”).content(“Shape 1”).content(“Path 1”).path
    Dan
  • Andrew Ross
    June 18, 2015 at 4:53 pm
    Oh so it does! Apologies for that. I jumped the gun too soon I guess. I tried it within the comp I had at the time, that exact thing, pick-whipping one shape path to the other and it didn’t work but i’ve just tried it in a fresh comp with only two layers and it worked fine, should have done that initially. Sorry for being a total doosh but thanks for your help anyhow.
    A
