Linking opacity expression wiggle with brightness
I’ve got one layer with a wiggle(4,100) and I have pick whipped it to a brightness effect (brightness and contrast) on another layer. I am gathering it’s not working because the values are different, % vs no.
How to I change it to get it to work AND change the subtly of the effect, meaning that when the wiggle goes to say 4% opacity, the brightness value is not so dark you cannot see the image?
Thank you!
thisComp.layer("Audience Retention").effect("Brightness & Contrast")("Brightness")Olly Lawer
