Activity Forums Adobe Illustrator Linking objects in Illustrator
  • Linking objects in Illustrator
    Posted by Isotrope on March 24, 2006 at 8:39 pm
    Hi everyone,
    I keep looking for this on the web and I keep coming up short.
    Can you link objects in Illustrator in the same way that you would link Layers in Photoshop (without Grouping)?
    I tend to have multiple copies of an object (one for the compound, one or two for fills and gradients blended, maybe one for the stroke,…) and would love it if I could link them all together. I know that I can create Selection groups, but I would like to be able to have this so that it would respond the same way as clicking on a Group.
    Thank you very much,
    iso
    Isotrope replied 20 years, 5 months ago 2 Members · 2 Replies
  • Mike Gondek
    March 26, 2006 at 1:36 pm
    Look into using the appearance palette. This is the way you can have one vector object, and assign multiple fills strokes etc to one editable object.
    The appearance palette is a little tricky to understand because of limited documentation, but once you master this palette you will see why appearance in illustrator is as important as layers are to Photoshop.
  • Isotrope
    March 27, 2006 at 11:12 pm
    Thanks Mike.
    I’m sorry I didn’t get back to you sooner. I was away.
    I am starting to get familiar with the Appearance palette. And yes, it does do a lot of what I need. But I would like to be able to link different shapes from different groups. Unless, you can have a shape within multiple groups(…?)
    Thank you very much for your input, it is much appreciated.
    Cheers,
    iso
