Activity › Forums › Adobe After Effects Expressions › Linking null object to track. How to add X offset?
  • Linking null object to track. How to add X offset?
    Posted by Boris Voinov on July 9, 2013 at 7:49 pm
    Hi all,
    I have three layers: motion path, null object and optical flare. I applied motion to null object and then linked its coordinates to optical flare. Now optical flare moves are the same as null object. In optical flare Position XY I have this expression: thisComp.layer(null3).transform.position. The question is: how to add an offset ot X coordinate? I need to place optical flare a little bit higher than the position of null object and keep the motion from my motion track.
    Boris.
    Boris Voinov replied 13 years, 2 months ago 2 Members · 2 Replies
  • Mitch Mann
    July 9, 2013 at 8:07 pm
    Maybe put a slider on the layer, and then add the slider’s value to your X in the expression. Perhaps something like this:
    myX = thisComp.layer(“Null 3”).transform.position[0] + effect(“Slider Control”)(“Slider”);
    myY = thisComp.layer(“Null 3”).transform.position[1];
    [myX,myY]
    Then you can adjust the slider until you get the offset to your liking.
  • Boris Voinov
    July 10, 2013 at 5:40 am
    i found different solution.
    anyway thx for the answer
    x=thisComp.layer(null3).transform.position[0]+100;
    y=thisComp.layer(null3).transform.position[1];
    [x,y]
