Activity › Forums › Adobe After Effects Expressions › Linking Mosiac Horizontal & Vertical Block controllers
  • Linking Mosiac Horizontal & Vertical Block controllers
    Posted by Gareth Hanks on August 1, 2008 at 11:18 am
    I’ll get my apologies out of the way with. I haven’t done a search!
    I’ve used AE for over a decade but I’ve never ‘done’ expressions. It’s a room that I have never opened the door too (well, I’ve kinda bent down to look through the keyhole & ran away screaming) but I feel it might be the only way to achieve what I want to do.
    I wish to tie together the Horizontal & Vertical properties of Mosaic. This is so that the ratio of 16:9 is consistent & I always have a square block result which I can then keyframe to enlarge/shrink.
    Is this possible with expressions? Or is there another way to achieve this?
    Expressions Virgin (well, 1st base maybe :S)
    Home – QuickSilver Duel 1Ghz 10.3.9 – 1.5 GB DDR SDRAM – 120Gb HD – AE 6.5
    Gareth Hanks replied 18 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 4, 2008 at 3:20 pm
    You should be able to use an expression like this for the horizontal blocks:
    effect(“Mosaic”)(“Vertical Blocks”)*16/9
    Dan
  • Gareth Hanks
    August 5, 2008 at 7:07 pm
    It’s that easy?
    I’m shamed. Thanks for this. I am trying to distress some video to try to achieve a look of a bad encoding & splitting the RGB channels to bring colour into the piece. Tieing the H & V together keeps the square look.
    Cheers 🙂
