Activity Forums Apple Final Cut Pro Legacy Linking Mini DV clips???
  • Linking Mini DV clips???
    Posted by Andrew on August 4, 2005 at 12:00 am
    I’m having trouble with MiniDV formatted footage in FCP in terms of editing the video and audio together. I have elected the ‘link command’ but the files won’t become one in order to cut up.
    Is there something else I need to select???
    Bret Williams replied 21 years, 1 month ago 3 Members · 3 Replies
  • Jerry Hofmann
    August 4, 2005 at 1:15 am
    The audio is sound synce from camera? If it is, then turning on linking should do the trick… have the files become unlinked? i.e. when you turn linking on, are the names of the audio and video clips in the timeline underlined?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Andrew
    August 4, 2005 at 1:20 am
    The audio is sound sync from the camera and the video and audio is underlined. Its weird huh?
  • Bret Williams
    August 4, 2005 at 4:05 am
    There are many linking options. Linked, stereo linked, and linked selection. Which are you referring to? If it’s just linked, not linked selection, then turn that on by pressing the linked seclection button in the upper rt hand of the timeline. You probably had it off, which means you have to hold down option to select them together. If it’s on, you have to hold down option to select them separately.
