Activity Forums Adobe After Effects Expressions linking luminace value to scale
  • linking luminace value to scale
    Posted by Criis Daw on March 16, 2010 at 5:12 pm
    Hi can anyone help me please.
    I am trying to create an expression where the luminace value of a layer dictates the z scale value of a precomp above it. I want it to work like a displacement map so the precomps scale at different values depending on the luminosity of the displacement image.
    I need to know how to write an expression that will determine what point of the displacment map to take the value from.
    Make sense ?
    Hope some one can help
    Cheers
    Dan Ebberts replied 15 years, 9 months ago 3 Members · 13 Replies
  • 13 Replies
  • Dan Ebberts
    March 16, 2010 at 5:24 pm
    Something like this should work:
    minScale = 0;
    maxScale = 100;
    L = thisComp.layer(“displacement image”);
    sampleSize = 1;
    point = L.fromWorld(toWorld(anchorPoint));
    sample = L.sampleImage(point,[sampleSize,sampleSize]/2,true,time);
    lightness = rgbToHsl(sample)[2];
    s = linear(lightness,0,1,minScale,maxScale);
    [s,s]
    Dan
  • Criis Daw
    March 16, 2010 at 5:29 pm
    Thanks Dan,
    I think i can get my head round it. Did you just write that ?
    I am very impressed…
  • Dan Ebberts
    March 16, 2010 at 5:34 pm
    I did. But I’ve had a lot of practice…. 🙂
    Dan
  • Criis Daw
    March 16, 2010 at 5:41 pm
    well its working….
    but the x and y are scaling and the z remaining the same. Its the reverse I am after.
    I am tying to work it out but ……
  • Dan Ebberts
    March 16, 2010 at 5:45 pm
    Sorry – that’s what I get for reading too fast. Try this:
    minScale = 0;
    maxScale = 100;
    sampleSize = 1;
    [value[0],value[1],s]
    Dan
  • Criis Daw
    March 16, 2010 at 5:53 pm
    Thanks i worked it out !
    well almost .
    i changed the last line to
    [50,50,s]
    and typed in suitable x,y values (50) and it works like i want.
    what does the command (value) meam / make it do ?
    thanks for your help.
  • Dan Ebberts
    March 16, 2010 at 5:59 pm
    value just retrieves the pre-expression, keyframed (or static) value. So if you set the scale of the layer to 50%, both versions should give you the same result.
    Dan
  • Criis Daw
    March 16, 2010 at 6:04 pm
    little by little I am getting better at them.
    I can even more or less understand the body of the one you sent me. Its a bit like learning a foreign language. Reading often comes more easily than speaking (well correctly at least) .
    again many thanks
    Chris
  • Anton Arkh
    August 19, 2010 at 1:19 pm
    Hello! I am a complete novice when it comes to expressions, so I have no idea how to create anything more complex than a wiggle expression.
    How easy is it to adapt this code that Dan wrote to a lens flare brightness? I have a black/white image that I want to use as a mask, so when the Flare Center is over the white area, the Flare Brightness goes up, when its over black, it’s at 0%
    Thank you very much in advance!
  • Dan Ebberts
    August 19, 2010 at 5:43 pm
    This should work:
    minBrightness = 0;
    maxBrightness = 100;
    L = thisComp.layer("your mask image");
    sampleSize = 1;
    point = L.fromWorld(toWorld(effect("Lens Flare")("Flare Center")));
    linear(lightness,0,1,minBrightness,maxBrightness);
    Dan
