Activity Forums Adobe After Effects Linking keyframes?
  • Linking keyframes?
    Posted by Lasse Gjertsen on February 28, 2012 at 7:04 pm
    Hey, my first post.
    I’m trying to do some advanced lip syncing for a cartoon character, and I will narrow it a bit down here to explain my problem.
    The shape of the mouth is gonna be a shape layer path. Say I make three different mouths adjusting the anchor points of the path in three keyframes after each other; one open (A), one closed (B) and one shaped as an O (C).
    I want to link these three mouths to some kind of controller. I’ve seen some tutorials that use time remapping on a precomp, which works fine if you want different static mouths representing the different sounds.
    But I’m gonna be difficult and demand interpolation! In other words; I want the mouth shape to be able to go from A to C, without going through B, and I want interpolation between A and C.
    Can it be done?
    If so, it would open up a lot of doors for making advanced, yet simple, facial animation. (I might be wrong, but I think it’s something like this they do to animate lip-sync in 3DS MAX and such.)
    Thanks 🙂
    Lasse Gjertsen replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
