Activity Forums Adobe After Effects linking keyframes from 2 layers or nulls to make strong track
  • linking keyframes from 2 layers or nulls to make strong track
    Posted by Hanna Dean on April 24, 2016 at 12:09 am
    is it possible to link 1 3d image layer to 2 track null points to keep the image still without shaking ?
    1 null on left side of the object
    1 null on right side of the object
    3d image layer in middle linking to 2 nulls null-left< 3dimage >null-right
    Walter Soyka replied 10 years, 4 months ago 3 Members · 3 Replies
  • Jon Simpson
    April 25, 2016 at 12:02 am
    This reads like an expression solution but I am just learning that myself.
  • Hanna Dean
    April 25, 2016 at 2:05 am
    what plugin i can get that does this mate
  • Walter Soyka
    April 25, 2016 at 10:18 am
    [hanna dean] “is it possible to link 1 3d image layer to 2 track null points to keep the image still without shaking ?”
    It’s possible to determine the midpoint of two points; whether the midpoint is still depends on the tracked points.
    Here’s the expression. Alt+click on the position stopwatch of the layer you’d to set at the midpoint between Null 1 and Null 2. (The formula for midpoint is just the average of each of the two points coordinates.)
    null1Pos = thisComp.layer("Null 1").transform.position;
    null2Pos = thisComp.layer("Null 2").transform.position;
    midPointPos = [ (null1Pos[0] + null2Pos[0]) / 2, (null1Pos[1] + null2Pos[1]) / 2, (null1Pos[2] + null2Pos[2] ) / 2 ];
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
