Activity › Forums › Adobe Premiere Pro › Linking effects and/or sending values between Premiere Pro and After Effects?
  • Linking effects and/or sending values between Premiere Pro and After Effects?
    Posted by Jeremy Mamisao on January 16, 2018 at 8:41 pm
    Hi all, I’m trying to find a workflow so I can link an effect I did in Premiere Pro with After Effects, specifically the Offset effect. So that when you modify the offset “shift center to” parameter in Premiere, it does the same thing for the same effect in After Effects. As for as I can tell so far, dynamic link works just for linking media but I’m wondering if there’s a work around.
    Alternatively, is there a way to send values from Premiere to After Effects? Could link up an expression to get it to work.
    Thanks for your help!
    Jeremy
    Jeremy Mamisao replied 8 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
