Activity Forums Adobe After Effects linking effects ?
  • linking effects ?
    Posted by Bernhard Rieder on November 18, 2008 at 2:55 am
    Let’s say I do have an HUE effect on one of my layers.
    And let’s say, I would like add the same effect on 5 other layers.
    I can simple copy and paste..
    but if I want to change later the HUE, I would love to change that just on one layer, and all other 5 layers will have the same change.
    How to do that ?
    Kevin Reiner replied 17 years, 10 months ago 3 Members · 2 Replies
  • Paul Conigliaro
    November 18, 2008 at 2:44 pm
    This can be done with expressions enabled and using the pickwhip tool.
    • Make sure the hue controls are visible in the timeline.
    • Pick which layer you want to be your master layer. On all your other layers, option/alt click on the add keyframe button. This will turn on expressions.
    • Using the pickwhip tool that appears (the little button with a swirl on it), click and drag to the “master” hue control.
    Now, whenever you change that one, anything linked to it will also change.
    CS3, FCS2
    [Note: Using Particular, 3-D Stroke, and now Form do not instantly make your designs “teh awesome.”]
  • Kevin Reiner
    November 18, 2008 at 3:40 pm
    And just to add to Paul’s post. I’ve recently taken up the habit of making an “effect control” subcomp. It works well for me because I am often working on campaigns that involve many Master comps in one project. So I make an effect control comp and keep my expression control layers there. If I need to change the color of a certain asset throughout my entire project, I can do so with the change of one value. Very time saving.
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.11
    Final Cut Pro Studio 2
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
