Activity › Forums › Adobe Premiere Pro › Linking audio to mimic video movement (track numbers)
  • Linking audio to mimic video movement (track numbers)
    Posted by Nathan Quattrini on January 26, 2007 at 3:38 pm
    Is there a way to make it act like the older versions of premiere? I want to move my video from V1 to V2 or 3 and have its corresponding audio do the same, move to A2 or A3 depending where I put the video file, so V2 and A2 are the end result for a moved clip, but only needing to drag the video and the audio goes on its own. Hope i explained it clear enough.
    Nathan Quattrini replied 19 years, 8 months ago 3 Members · 3 Replies
  • Robert Hallion
    January 26, 2007 at 3:52 pm
    As long as they are linked they will move together. Unless you have mono audio and you are trying to move them to a stereo channeled track, in that case it won’t work. You have to create new audio tracks that are mono.
  • Mike Velte
    January 26, 2007 at 3:55 pm
    If memory serves me, Premiere 6.x would do that but not allow an audio clip to overlay an existing audio clip in the process (timeline signal). Premiere Pro will not advise you with a timelime signal that you are about to overlay one audio clip on top of another.
  • Nathan Quattrini
    January 26, 2007 at 3:58 pm
    I should have said i`m using PPRO 2.0
    It doesn`t, when i drag the video to different tracks the audio follows it left and right, but remains on the same track and over writes any other audion it lapses. Very inconvenient for lots of short clips that need re-arranging.
