Activity Forums Apple Final Cut Pro Legacy Linking Audio and Video
  • Linking Audio and Video
    Posted by Tony Robinson on July 11, 2009 at 10:55 pm
    Ok, so I’m editing a feature where the video was recorded and captured separately from the audio. I’ve gone through and synced up each “take” to the audio for that “take” in sequences. No problems there. However, because I’m editing 1080p ProRes in a 720p ProRes sequence for the final film (want to be able to re-frame, pan, and zoom), whenever I drop a “take” sequence within that main sequence it must render before it will play at all. If I drop just a video clip (not synced with audio in a nested sequence) it will play just fine (albeit preview quality). How do I overcome this? I know I could export each nested sequence as it’s own Quicktime movie with the audio included and use those. But that is doubling my harddrive space and taking lots of time. I need to just link the video with the synced audio so I can drag them as a single clip into the primary sequence OR figure out a way for FCP not to have to render just because it’s a nested sequence. I appreciate any ideas!
    Cheyo Masters replied 16 years, 10 months ago 4 Members · 5 Replies
  • Jeremy Talcott
    July 11, 2009 at 11:38 pm
    Rather than dumping a nested piece of a sequence from the source window, if you merely mark in and outs in your source sequence in the timeline (and having linked audio with this video, I assume) and then copy and paste into your final sequence you shouldn’t have to render, I believe. This does mean that you have to alter your normal editing behavior, however, and may be slower. But I would far rather use that method than deal with the rendering.
  • John Fishback
    July 12, 2009 at 2:06 am
    Selec both the video and audio tracks and Cmd-L will link them. If you have 2 audio tracks Cntl-L will switch them from mono to stereo. If the addition of audio is causing you to have to render, check that the audio sample rate is 48kHz. This is the sample rate FCP (and most pro video apps) wants to see.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Tony Robinson
    July 12, 2009 at 2:26 am
    John,
    Thanks, that’s exactly what I needed. It’s amazing how even after using FCP for years I can be lost when I need to do something that I’ve simply never had to do before!
    Tony Robinson
  • Cheyo Masters
    November 16, 2009 at 11:27 pm
    How do you link multiple files? I have a sequence with just cuts but my audio and video clips become unlinked. how do I link all of them at one?
  • Cheyo Masters
    November 16, 2009 at 11:28 pm
    How do you link multiple files? I have a sequence with just cuts but my audio and video clips become unlinked. how do I link all of them at once?
