Linking a position dependent effector to a change in position.
I was wondering if anybody has tried making an expression for effectors like “Bend It”–which require a start and end coordinate–when the layer it is applied to is moving. Currently, I hard code the start position value and then subtract the current position value by pick whipping the value.
Does anybody know if there is a way where I can avoid hard-coding values?
Thank you
x = effect("CC Bend It")("Start")[0];
y = effect("CC Bend It")("Start")[1];[x, y + (transform.position[1] - 251.5 )]
