Activity Forums Adobe After Effects Linking a layer to part of a Puppet Mesh
  • Linking a layer to part of a Puppet Mesh
    Posted by Ahmed Aldawood on May 17, 2020 at 1:37 pm
    Hello,
    So basically I have two seperate animated layers and one of them [ The secondary ] is supposed to be attached to the other [ The main ] but for ease of animation I seperated them. Now, I want the secondary layer to be attached to a part of the main layer’s Puppet Mesh without adding a Pin to the mesh because adding a pin will sacrifice the movement factor of that specific part of the mesh unless I animated it which will just cause more hassle.
    I used the expression below and it worked but the secondary layer isn’t following the main’s movement which results in an unaturally still animation.
    l = thisComp.layer("PUPPET_LAYER");
    l.toComp(l.effect("Puppet").arap.mesh("Mesh 1").deform("Puppet Pin 1").position);
    Is there a way to attach the secondary layer to a part of the main’s mesh so that the secondary follows the movement of that part specifically?
    Chaz Chester replied 6 years, 3 months ago 2 Members · 1 Reply
  • Chaz Chester
    May 18, 2020 at 2:58 am
    It might not be the most elegant solution, but you could pre-compose the puppeted layer and motion track the spot that you’re trying to attach the secondary layer to.
