Activity Forums Adobe After Effects Expressions Linking a keyframe to a specific slider control value
  • Linking a keyframe to a specific slider control value
    Posted by Tobias Ochott on June 7, 2017 at 4:45 pm
    Hello again:
    so here is what i got
    i got an ellipse shape with trim paths which contains two keyframes
    the first one has the the value 0 the second one should be the value a slider control has at this time and keep it for the rest of the comp
    i tried this expression:
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = 0;
    v2 = effect("Slider Control")("Slider");
    linear(time,t1,t2,v1,v2);
    }else
    value
    but it doesnt work because the slider control itself has no changing value
    Dan Ebberts replied 9 years, 2 months ago 3 Members · 4 Replies
  • Scott Mcgee
    June 7, 2017 at 7:35 pm
    Hey Tobias,
    Not sure what you are trying to do.
    The expression is fine, if you are wanting to change the input of Keyframe 2 with a value defined by your slider.
    How do you want the value to change? Based off what you described firstly, your expression is fine.
  • Dan Ebberts
    June 7, 2017 at 7:38 pm
    At which time? Your expression works the way I would expect it to–the value ramps from zero to whatever the slider is set to over the period defined by the two keyframes on the property with the expression.
    Dan
  • Tobias Ochott
    June 7, 2017 at 8:14 pm
    First of all thanks for the fast answer
    So i want the following
    I have a slider control that changes its value over time
    now i want another layer, lets say an ellipse with trim paths, to adapt the values of the slider control up to a certain point in time and hold the last value it got
    the problem with my expression here is that the slider control itself doesn’t change its values
  • Dan Ebberts
    June 7, 2017 at 8:21 pm
    I’m lost.
    Dan
