Activity Forums Adobe After Effects Expressions Linking 2D and 3D layers for character rig
  • Linking 2D and 3D layers for character rig
    Posted by Matt Exton on February 11, 2016 at 12:49 pm
    Hi all,
    Apologies if this has been covered in another post somewhere but I’ve searched a while now and can’t seem to find an answer so here goes…!
    I have a scene with a foreground, mid ground and background that are separated in 3D space in order to give me a sense of depth.
    The shot starts wide, zooms in to the BG and then zooms back out to the MG.
    When it zooms back to the MG, 3 characters appear.
    I have rigged the characters in 3D space, however I am using a plugin called “Rubberhose” to animate the limbs, and this (from what I’ve seen) can only be used as 2D layers.
    When the camera stops, I have switched the layers from the 3D static arms to the 2D arms so I can use the effect.
    However…
    I wish to link the shoulder null to the body which is 3D, so it moves with the position of the body.
    I have tried using the following expression on the 2D layer.
    this_comp.layer(“shirt”).to_comp([0,0])
    This works, but it moves the shoulder to a different position from it’s original, and I can’t move it back into position as the position values are now linked to the 3D layer.
    I can parent the shoulder to a null and move it into position this way but I wondered if I’m overcomplicating things and if there was an easier way to do it?
    Thanks in advance for any help!
    Matt
    Miguel De mendoza replied 10 years, 6 months ago 2 Members · 1 Reply
  • Miguel De mendoza
    February 11, 2016 at 1:34 pm
    At first, you must write “toComp” instead of “to_comp”.
    Second, do you need to call toWorld instead toComp, because you are geting a 3D value.
    But I think the real problem is the perspective, because I can see that the arm you are trying to link is bigger than the back arm.
    I think the best way to solve it(and the normal way to animate characters) is to animate character movements inside a character comp, where all the components are 2d, and make this comp 3d in your scene.
