Activity Forums Adobe After Effects Expressions Linking 2 camera’s in different comps at a specific time
  • Linking 2 camera’s in different comps at a specific time
    Posted by Mark Doctor on September 14, 2018 at 4:39 pm
    Hi guy’s
    I’ve got two comp’s
    The comp “Background” has been pre-composed in the “MainComp” and contains a Camera.
    The “MainComp” needs to have the same camera movements. For easy updating I use the expression:
    comp("BackGround").layer("Camera").transform.position;
    Because the “BackGround” layer also needs to be time-remapped, we need to use the camera value at a specific time
    valueAtTime(thisComp.layer("BackGround").timeRemap);
    However the code:
    …will not work because the value form the “Camera” never got stored in the value key-frame.
    So how do i glue these expressions together?
    thank you for your time, Mark
    Mark Doctor replied 7 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 14, 2018 at 5:30 pm
    I haven’t tested this, but it seems like it would be like this:
    comp(“BackGround”).layer(“Camera”).transform.position.valueAtTime(thisComp.layer(“BackGround”).timeRemap);
    Dan
  • Mark Doctor
    September 14, 2018 at 6:03 pm
    It works! Thank you for your time Dan ????
