linked illustrator problem
Hello,
I did a quick search and couldn’t find this problem posted anywhere.
I’ve had this problem a number of times in AE CS4. I don’t get an error and can’t figure out what the problem is.
I’m using layered illustrator files and every once in a while, After Effects will read the layers as either empty or strangely cropped. Again, no error message, but something about the exchange is clearly off. Doing a footage reload doesn’t fix it either, I have to do a replace footage and re-import the layer to clear things up.
Anybody else have this issue? It’s pretty frustrating when you look at your rendered QT and there are big holes in the animation!
Jon
