Activity Forums Adobe Premiere Pro Linked AE Comp goes offline when re-edited in AE
  • Linked AE Comp goes offline when re-edited in AE
    Posted by Steve Brame on November 13, 2013 at 1:55 pm
    I’ve linked a few comps from a single AE project into Premiere. Everything works well, until I ‘Edit Original’, then close AE after editing one of the comps, and return to Premiere. At that point all of the comps have gone offline. Re-linking is simple enough, or I can simply restart Premiere and open the project, then they’re all back.
    Since I’m not seeing this being reported at Adobe’s forum, or here for that matter, I’m figuring it’s machine specific, but wanted to throw it out there in case I’ve missed something here in my search for the issue.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Casey Culver replied 11 years, 6 months ago 3 Members · 3 Replies
  • Casey Culver
    November 13, 2013 at 5:15 pm
    I’ve had the same problem – especially when I’m linking to more than one AE project.. So I try to and make sure and keep to one AE project. I’ve also read along the way that if you start up AE first, the dynamic link sticks a little better. It’s not perfect yet..
  • David Seay
    February 18, 2015 at 6:09 pm
    I’m having the same off-line AE issue. Were you able sort that problem out?
    TV- It’s why Kennedy beat Nixon
    david seay
    https://www.davidseayproductions.com
  • Casey Culver
    February 18, 2015 at 6:36 pm
    I personally haven’t had this problem since I’ve upgraded from CS6 to CC, however, I’ve also been much more picky about what exactly I send to AE. What version of PP and AE are you using? And what are you doing in AE that you’re not able to do in PP?
