Activity Forums Apple Final Cut Pro Legacy Link to P2 files from different computer
  • Link to P2 files from different computer
    Posted by Katie Van on April 30, 2008 at 12:33 am
    This must be a remedial question because it’s such a fundamental issue, but this is my first P2 project and I’m trying to catch up fast!
    Our MXF files are all on external firewire drives, usually staying hooked into one computer. If I hook a drive into a different computer (with the same project) can I just relink like I would with QTs or do I have to ingest everything all over again?
    Steve Eisen replied 18 years, 4 months ago 2 Members · 2 Replies
  • Katie Van
    April 30, 2008 at 4:27 am
    Ok I figured out that ingesting turns clips into QTs that can be moved. Any suggestions on a good compression size for the copies?
  • Steve Eisen
    April 30, 2008 at 12:28 pm
    You cannot change the compression of the QuickTime files.
    If you use Raylight (https://www.dvfilm.com/raylight/mac/index.htm), you can work with the MXF files natively inside FCP.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
