Activity › Forums › Adobe After Effects Expressions › Link to expression in precomp, but unique to each time precomp is used.
  • Link to expression in precomp, but unique to each time precomp is used.
    Posted by Christiaan Vee on November 8, 2022 at 3:36 pm
    I’m unsure how to link to an expression in a precomp multiple times.
    Example… In ‘Base_comp’ I have three layers of the same ‘Pattern_comp’.
    In ‘Pattern_comp’ I have a dropdown menu that specifies ‘Pattern A’, ‘Pattern B’ and ‘Pattern C’, which then displays the corresponding pattern.
    What I would like to do is in ‘Base_comp’ on layer 1 add a dropdown menu set to 1, which would then select Patter A. On layer 2 I could have the dropdown set to 2. Layer 3 = 2 (or whatever). So each layer would have a different dropdown that each drives the dropdown in the corresponding precomp.
    What I tried to do, which obviously didn’t not work, is pick whip the ‘Pattern_comp’ dropdown menu to the ‘Base_comp’ layer 1 dropdown. Gives me correct pattern on layer 1, but not layer 2 or 3.
    Hope that is clear. Any help is greatly appreciated.
    Christiaan Vee replied 3 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 8, 2022 at 4:41 pm
    I don’t think you’re going to be able to make that work. You’ll need to duplicate your Pattern_comp in the Project panel, not as a layer in your Base_comp, then you should be able to link each copy independently.
  • Christiaan Vee
    November 8, 2022 at 4:57 pm
    Thanks for the reply, I agree I don’t think it’ll work.
