Activity › Forums › Avid Media Composer › Link to AMA turns clips green with HDV1080p24 footage
  • Link to AMA turns clips green with HDV1080p24 footage
    Posted by Dan Janos on April 15, 2013 at 12:39 am
    When Linking to AMA files in a 1080p/23.98 project, my HDV footage shot at 24p turns green in the source window. Same deal in the bin when I choose frame view. HDV footage shot at 29.97 works just fine. 720p24 footage looks good too.
    So, is this an unsupported format for AMA linking, or is there some other problem at work here?
    Thanks for your help.
    Running MC6.5 on Mac Powerbook with 2.8GHz
    Dan Janos replied 13 years, 5 months ago 2 Members · 8 Replies
  • 8 Replies
  • Michael Phillips
    April 15, 2013 at 1:02 am
    Does it decode the same way when in a 1080p/24 (24.000) project?
    Michael
  • Dan Janos
    April 15, 2013 at 1:42 am
    I’m afraid so. Just tested linking in a new project with 1080p24 settings with same results – 1080p23.98 footage turns green, 720p24 footage is fine.
  • Michael Phillips
    April 15, 2013 at 1:49 am
    Very strange – do those clips open in another application with no issues?
    Michael
  • Dan Janos
    April 15, 2013 at 3:13 am
    Yeah, no issues what so ever. I can open in QT, FCP, etc.
  • Michael Phillips
    April 15, 2013 at 2:45 pm
    Very strange – nothing comes to mind that would solve this other than a workaround to export out as QT wrapped DNxHD from those other programs.
    Can you send a small clip with the problem to me? I can look a few different things on my system just in case. Use wetransfer or yousendit.. to michael(at)24p(dot)com
    Michael
  • Dan Janos
    April 15, 2013 at 5:54 pm
    Thanks Michael. I’ve sent you a test clip. I’ll include some screen shots via email that might be helpful to unravel this.
  • Michael Phillips
    April 15, 2013 at 5:59 pm
    Just got it – I see that it is is a Apple HDV codec at 1080p/25. Does that sound correct? Is this the original camera file, or has it been transcoded somewhere along the way?
    Michael
  • Dan Janos
    April 15, 2013 at 6:47 pm
    These are native files that were Log and Transferred in FCP to unwrap them from the card.
    HDV 1080p/24 is what I see in the QT movie inspector on my end.
