Activity › Forums › Adobe After Effects Expressions › Link text problem with expression
  • Link text problem with expression
    Posted by John Koronaios on December 1, 2021 at 12:59 pm
    Good morning to everyone!
    I have the following problem.
    I link a text to get the data automatically.
    When I connect only one text and modify the layer style with expressions, it works normally.
    When I connect and the second text, it does not show me the double texts, but sends me a message [objectObject]
    What i must change in the expression to make it work normally?
    Thank you in advance
    best wishes
    John K.
    Kevin Camp replied 4 years, 9 months ago 2 Members · 5 Replies
  • John Koronaios
    December 1, 2021 at 1:04 pm
    I want the final text have the Name with Other font and the Surname with other font…Like this.
    For this reason i try to connect two diferrnet layer styles in the same text with expression…Other idea?
  • Kevin Camp
    December 2, 2021 at 12:36 am
    I don’t think you’ll be able to do this with a text style expression, as style is applied to the whole text layer, not a partial string.
    If you want one name regular (or light) and the other bold, I think you will need to make them separate text layers and then use a sourceRectAtTime() expression to make the second text layer follow the first, as if it were a single text layer.
    Try this:
    Create two text layers and parent layer 2 to layer 1.
    Add this expression to the position property of of layer 2:
    rect = parent.sourceRectAtTime() ;
    x = rect.left + rect.width ;
    [ x, value[1] ]
    Layer 2 should now follow layer 1 as you modify layer 1’s source text as if they were both on the same text line.
  • John Koronaios
    December 2, 2021 at 9:45 am
    I try and this but… :/
    Please if you have some idea help…
  • John Koronaios
    December 2, 2021 at 9:48 am
    I try and this with parent and Rect expression but didn’t wotk….
  • Kevin Camp
    December 2, 2021 at 4:50 pm
    For my set up, i was thinking you’d want each text layer lined up by their y-axis (like it is on a single line of text), and then the expression would go on the Position property rather than the Source Text property.
