Activity Forums Adobe After Effects Link pre-compositions into external projects
  • Link pre-compositions into external projects
    Posted by Dennis Dillert on May 25, 2009 at 1:54 pm
    Hi guys, is it possible to link one pre-composition to another project? I have the same file in several projects and want to achieve that when I update one version of it, all other projects that have this composition linked get updated as well.
    Rendering doesn’t work because I want to keep the flexibility and adjust certain things afterwards.
    Is there a way to do that?
    Julian Harding replied 17 years, 3 months ago 3 Members · 3 Replies
  • Simon Bonner
    May 25, 2009 at 4:12 pm
    I wish! If there is a way, I’d like to hear about it too.
    When I’m doing something similar, I save the precomp into a project of its own. Then, when I have another project open that uses it, I import the procomp project and – in the final comp – replace the older precomp layer with the newer one. Then I delete the older imported precomp project folder.
    A bit round-the-houses but the best way I’ve found so far.
    Simon Bonner
    youtube.com/simonsaysfx
  • Dennis Dillert
    May 25, 2009 at 4:43 pm
    .. ahh ok. So far I’m doing the same. But it gets quite tricky the more files you have. I thought the guys from Adobe already thought of that. Well, maybe it’s not the actual idea of a “quick” composite.
    It would definitely enhance the productivity.. and I’m still waiting for Adobe to introduce folders in the layers part like you have in Photoshop. Let’s wait for CS5.. ;o)
    Thanks for the feedback Simon.
  • Julian Harding
    June 8, 2009 at 1:08 pm
    It does seem a shame that there are no folders in layers yet, it’d make it easier to navigate in situations where pre comping can’t be used! Though render orders may get confusing once the folders are collapsed…
    https://www.vimeo.com/jgharding
    https://www.myspace.com/jgharding
