Activity Forums Adobe After Effects Expressions Link position value to frame number
  • Link position value to frame number
    Posted by Patrick Murphy on March 3, 2014 at 9:32 pm
    Hello helpful folks!
    I’m trying to make a chin on a character move to certain mouths on a time remapped layer.
    How would I start this?
    I want to have 3 different frames from a time remapped layer move the position of a chin layer slightly down then the other frames move it back up to the original position.
    Im guessing I would put the expression on the position of the chin layer, telling it to move when the remapped mouth layer hits certain frames. Ie. be in position x at frames 2, 4, 6 and be at position y at frames 1, 3, 5.
    Any help is always much appreciated. Thanks!
    Patrick Murphy replied 12 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • Patrick Murphy
    March 3, 2014 at 9:52 pm
    Here’s what I’ve gotten so far….
    I put this on the position of my chin layer:
    A = framesToTime(thisComp.layer(“Mouths.mov”).timeRemap);
    B = [377.5, 606.0]; // chin down
    C = [377.5, 597.0]; // chin up
    if (A == 7){B;} else{C;}
  • Dan Ebberts
    March 3, 2014 at 10:24 pm
    The timeRemap value is going to be in seconds, so I think you’ll need to use timeToFrames() instead.
    Dan
  • Patrick Murphy
    March 3, 2014 at 11:02 pm
    That worked but say I want more than just one frame to move the position, would I add an array? Or is there some way of bracketing that says if the value is one of these numbers then B?
    A = timeToFrames(thisComp.layer(“Mouths.mov”).timeRemap);
    B = [377.5, 606.0]; //chin down
    C = [377.5, 597.0]; //chin up
    D = [2,3,6,9}; //frames to move chin down
    if (A == D){B;}else{C;}
    Thanks so much for your help.
  • Dan Ebberts
    March 3, 2014 at 11:12 pm
    This would be one way (not tested):
    A = timeToFrames(thisComp.layer("Mouths.mov").timeRemap);
    D = [2,3,6,9]; //frames to move chin down
    val = C;
    for (i = 0; i < D.length; i++){
    if (A == D[i]){
    val = B;
    break;
    val
    Dan
  • Patrick Murphy
    March 3, 2014 at 11:25 pm
    It works, you are the man!
    Does that mean your turning the values in D to 0 and if it’s not 0 then use C?
    I’m just trying to understand it. Thanks for your patience.
  • Dan Ebberts
    March 3, 2014 at 11:31 pm
    No, the last part assumes the result (val) will be C, but then it loops through array D, looking for a match. If it finds one, it uses B instead.
    Dan
  • Patrick Murphy
    March 3, 2014 at 11:45 pm
    Thank you!!!
