Activity Forums Adobe After Effects Expressions Link position to scale expression ?
  • Link position to scale expression ?
    Posted by Lucas Piazzini on April 14, 2020 at 12:49 pm
    Hello guys ! First of all hello, this is my first post here ☺
    I am doing a bouncing ball animation with expressions and would like to create it’s shadow. I’d like to make it scale based on the ball’s height (position, more generally), but I am quite running out of ideas to transcribe it’s height into a %.. I need help please !
    Thank you for the answers in advance =)
    Lucas Piazzini replied 6 years, 4 months ago 3 Members · 5 Replies
  • Andrei Popa
    April 14, 2020 at 2:22 pm
    https://www.youtube.com/watch?v=no9gtkH3sGY
    Andrei
    My Envato portfolio.
  • Lucas Piazzini
    April 14, 2020 at 2:23 pm
    Thank you very much !
  • Scott Mcgee
    April 14, 2020 at 2:28 pm
    This is kind of what you want. I don’t have anything that caps it at a percentage, but hopefully it’ll get you started.
    posTwo = thisComp.layer("Shape Layer 2").transform.position.key(1).value[1];
    currentPos = thisComp.layer("Shape Layer 2").transform.position[1];
    x = transform.scale[0] - (100 - (currentPos/posTwo)*100);
    y = transform.scale[1];
    [x,y]
  • Scott Mcgee
    Just seen Andrei has answered you, hahaha. So ignore me.
  • Lucas Piazzini
    April 14, 2020 at 6:23 pm
    After hours of headaches and with the help of my Data scientist father, I was able to make a much simpler and versatile version that revolves around no other constant than a factor unlike school of motion, it also allows you to control the speed of evolution from minimum scale to maximum scale, aswell as the minimum scale ! Thanks for your help I wouldn’t have improved without your link !
    Factor = 20 //Control the scale variation, smaller factor = smaller minimum size
    var diameter = thisComp.layer("Ball").content("Ellipse 1").content("Ellipse Path 1").size[1];
    var ball_yPos = thisComp.layer("Ball Pos").transform.position[1];
    var ground = thisComp.layer("Ground").transform.position[1];
    var hDepart = diameter*2; //Control the scale speed
    var diff_BallGround = ground - ball_yPos;
    if (diff_BallGround<hDepart){ //Shadow Scaling
    substract = (diff_BallGround/Factor)
    }else{
    substract=hDepart/Factor // Minimum size
    if (substract&lt;0){ //To prevent the shadow from getting larger
    substract = 0
    [100-substract,transform.scale[1]]
