Activity Forums Adobe After Effects Expressions Link parameter to time?
  • Link parameter to time?
    Posted by Noel Powell on May 19, 2012 at 6:11 am
    Hi, I’m wondering if there’s an expression to continuously change a parameter without using keyframes and without the parameter ever repeating the same value (so the wiggle expression is out). The parameter I want to change is the evolution of a Fractal Noise effect. It needs to steadily increase in a linear fashion (not randomly) – so I guess eventually, it would have to loop, since it only goes up to 90 360-degree revolutions or something. Is there maybe a way to link the evolution to the comp’s time code value?
    Thank you!
    Noel Powell replied 14 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 19, 2012 at 6:44 am
    Something like this should work:
    rate = 50; // degrees per second
    rate*time
    Dan
  • Noel Powell
    May 19, 2012 at 1:41 pm
    That is perfect. Thanks so much.
