Activity › Forums › Adobe After Effects Expressions › Link Layer Marker to Composition Marker
  • Link Layer Marker to Composition Marker
    Posted by Gregory Wannwitz on May 14, 2022 at 9:41 am
    Hello
    I would like to link the position of Layer Markers to Composition Markers to control a time remap.
    It is a little bit hard to explain, so let’s say I have a “TEST COMP” in wich I put multiple instances of “00_anim_” and “01_anim_” comps.
    Inside the “00_anim_” and “01_anim_” comps I have time remap to control when start the animation, based on an excellent technic from Dan Ebbert, it works inside the compositions, but I would like to control the time remap directly on the composition with markers in another composition, so I would be able to offset the animation starts at different time for the various intances.
    But when I try to link my “marker.key(1)” to the “Comp.marker.key(1)” and “marker.key(2)” to “Comp.marker.key(2)” to control it outside of the “anim” comps that does not work.
    I put here a light AE project to help.
    Thanks in advance for your help.
    Gregory Wannwitz replied 4 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
