Link Color of Anything to Solid’s Color
Hi there!
I’m using the plugin called Templater. It allows you to use data from Google Datasheets to change some layers (like text/pitures, etc.). But it’s not the point.
The point is it can only change colors of solids, not shape layers or anything else. But I want colors in my composition to be editalble so I want to link colors of text and shape layers to the solid’s color. I believe there is way to do this, but the problem is I have no idea how. You can’t take a pick whip and simply link the colors because solids have no such property as ‘color’ or ‘fill’.
Maybe there is a way to do this with an expression? I would be much grateful for any help or advice.
