Activity › Forums › Adobe After Effects Expressions › Link Camera with different comp resolutions
  • Link Camera with different comp resolutions
    Posted by Raphael Ben on September 7, 2021 at 1:44 pm
    Hello,
    Here is my problem :
    I have a comp A with a standard resolution 1920×1080 with a 3d scene.
    I have a comp B with the same ratio but much more higher resolution (10240×5760 to keep details from a projection mapping)
    The comp B is inside the A but fit in height and width.
    I want to link both camera but of course the coordinates are really different.
    How can I do that ?
    Thanks in advance !
    Filip Vandueren replied 5 years ago 2 Members · 1 Reply
  • Filip Vandueren
    September 8, 2021 at 9:55 am
    • Select the camera in your smaller comp
    • edit > copy with property Links
    • paste the linked camera in your larger comp.
    Add “*(10240/1920);” to the expressions of these properties:
      • Point of Interest
      • Position
      • Zoom
      • Focus Distance
      • Aperture
      So for example, they will become something like
      comp("Comp 1").layer("Camera 1").transform.pointOfInterest*(10240/1920);
      I think that’s all you need.
      If the camera is parented to things, it becomes a bit more difficult though.
