Activity › Forums › Adobe After Effects Expressions › Link an object to a transition…
  • Lee Gibbons
    April 25, 2011 at 9:48 pm
    ahaha sorrry i opened it and i dont think im taht advanced yet I dont even know whats going on!
    basically I am doing a pan through a wall to the other side using 2 different video footage I have filmed. and I am doing it very simply but it is working by having a linear wipe going across as the came goes into the wall, But Because its hand held I want the brick work in between the walls to track perfectly with the linear wipe :S does that make sense? I tried track motion but that does not seem to work.
    thanks for the quick reply I believe I am going to post on here a lot haah
  • Lukasz Pason
    April 26, 2011 at 4:41 pm
    https://dl.dropbox.com/u/98105/matchcut.aep
    If I understand what you are trying to do, you are trying to do a match cut with panning footage. You should just be able to key frame the position of the incoming footage to match the speed of the outgoing footage. See if that’s what your trying to accomplish. Also… you might want to take a look into this and see if it will help you out.
    https://www.videocopilot.net/tutorials/submerged/
    Motion Designer / DJ / Father
    http://www.lukaszpason.com
    http://www.krop.com/lukasz
Page 2 of 2
