Activity Forums Adobe After Effects link an AE-Ligth to an AE-Spotligth
  • link an AE-Ligth to an AE-Spotligth
    Posted by Susan Lan on August 17, 2015 at 12:04 pm
    I created this 2 AE ligths. The AE-spot is using Trapcode Lux to make the cone ligth. ¿How to link the two ligths please?
    see the picture of the 2 ligths:
    https://i.imgur.com/ax7S2XS.jpg
    I try this expression in Position but dot not work
    L = thisComp.layer(“Ligt 1”);
    LCP = L.toComp([0,0,0]);
    LLP = thisLayer.fromComp(LCP);
    View post on imgur.com
    Susan Lan replied 11 years ago 2 Members · 3 Replies
  • Cassius Marques
    August 17, 2015 at 5:24 pm
    I’m starting to think you’re messing things up.
    Which lights are you trying to link? The two that you created in AE?… just shift parent one to another. As you would any other layer.
    Lux, assuming you applied it to a solid the same size of your composition, should automaticaly place the fake volumetric light at the appropriate light’s position.
  • Susan Lan
    August 18, 2015 at 5:16 pm
    Thank you
  • Susan Lan
    August 18, 2015 at 5:18 pm
