Activity › Forums › Adobe Encore DVD › link a menu without a break from one second
John Cuevas replied 20 years, 7 months ago 2 Members · 13 Replies
John Cuevas
February 16, 2006 at 2:03 pmStef
That is a problem I have run into also. If you set your loop point correctly and let it play over and over, it will loop back to the 10 second spot. Once you go to a timeline though it goes and finishes, it returns to the beginning of the menu, correct?
The only way around this is to make 2 menus. One menu for the first time, when you want the buttons to explode into place, and then a second menu when they are already in place.
Really there are two ways to accomplish this. You make your first menu only the first 10 seconds when your buttons explode into place. Then a second menu for the next 50 seconds. The first menu has an “end action” that points to the second menu. Menu’s load quickly, so the pause would be very brief. All of your timeline end actions will point to the second menu.
The second way is to just create a second menu. I think this would be easier, click the menu you have, duplicate it. Now in the copy, delete the background movie. Now in premiere, make an .avi of the last 50 seconds of your movie. Import that into Encore and set that as the background in the second movie. Now set all the end actions of the timelines to go to the second menu.
No worries about the english. Glad your project is working out for you.
johnny -
Stef
February 16, 2006 at 11:16 pmhey Jhonn.
thamks. i made a second menu (the same) without the first 10 seconds and it works great. THANKS THANKS you adobe nurt. i like that,but……
i used a buton from adobe encore and wil change the highlight but de adobe photoshop tels me that if i made a circle aroud a part of the highlight i will delete, adobe photoshop tel me the folowing note: ”Could not complete your request because the content of the layer is not directly editable…..
how can i put this of, so i ca change the high light.
i hope this is the las thing i strugle with it.
speak to you soon, and also thanks a lott anyway.
greatings Stef -
John Cuevas
February 17, 2006 at 2:00 pmOkay, in photoshop you have your button, which will be in a layer set. Twirl open the folder and click on the highlight layer. I think perhaps you were on another layer and that’s why the you weren’t able to edit the highlight layer.
That’s really the only thing I can think that would cause a layer to not be editable.
Glad everything worked out and I was able to help,
johnny
