Activity Forums Apple Final Cut Pro Lingering “phantom” audio
  • Lingering “phantom” audio
    Posted by Casey Hayward on February 27, 2012 at 9:50 pm
    I have an hour long timeline. Right near the middle I was moving some clips around and after I had moved a clip its audio continued to play in the same spot. There is no visible clip there anymore (just a gap now) but I can still hear it if I ply through the gap or put any other clip there. This does not involve an audition or compound clip. I am running 10.0.3.
    *Update*
    I tried deleting everything 2 minutes on either side and this audio still plays. I deleted all my project render files, reopened and the clip is still playing in the middle of nowhere
    Joseph Mcdonald replied 13 years ago 6 Members · 7 Replies
  • 7 Replies
  • Don Smith
    February 27, 2012 at 10:08 pm
    I just had something similar happen.. I split a clip to cut out a few seconds and dressed up the timeline. I started hearing the phantom, as you call it. I expanded the clips and saw that the cut didn’t take out the audio and after the timeline tightened up, the extra audio sounded below the clip that came earlier. I forget the details but I could not make it go away simply by dragging back the extra audio. It seemed to be a bug in the system. I think if you expanded the clips surrounding the gap you’ll see the dangling audio.
    NewsVideo.com
  • Mark Morache
    February 27, 2012 at 11:32 pm
    Same thing happened.
    Use the V tool to try to isolate the problem clip.
    Once you find the clip with the phantom audio, select the clip in the timeline and opt-cmd-C to copy the properties, use a shift-f to find the clip in the bin, then replace the clip in the timeline with itself (the clip in the bin), then opt-cmd-v to paste the properties back onto the clip.
    You may need to do some audio trimming if you created a split edit.
    This was the simplest way I found to work-around this bug. And it is a bug.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • David Eaks
    February 28, 2012 at 9:50 am
    I’ve had this “Phantom Audio” as well. I ended up finding 1 frame of a clip, between two clips, but with its audio extending some 40 mins under the rest of the project. It was driving me crazy!
  • Casey Hayward
    February 29, 2012 at 9:13 pm
    What do you mean by “V tool”?
  • Casey Hayward
    February 29, 2012 at 9:19 pm
    Ok,
    Thank you all for your help! I used the timeline index to track all instances of this short “phantom clip” I found an invisible one at the beginning of the timeline. I’m not sure why the audio was playing back in the middle of the timeline. I could not see or grab on to the clip so I deleted it in the index and this solved it. Thanks again.
  • Bene Jourdier
    June 27, 2012 at 9:54 am
    Hello,
    We have a same problem. A phantom audio in timeline.
    We can’t see the clip audio, it’s a big clip, hide on the principal scenario.
    We don’t understand your advices. Can you gives more details, please.
    We try but nothing happen !
    We become crazy 😉
  • Joseph Mcdonald
    May 2, 2013 at 8:04 pm
    I had this issue as well. I found that the phantom audio was attached to a specific video clip by deactivating each clip in my storyline one at a time with “v”. When I found the right clip, deactivating it removed the phantom audio. When I “expanded audio/video” on this clip, which was 3 clips to the left from the phantom audio, the audio track showed up. somehow it had gotten slid over from the video and it was not visible because it was still attached to the original video clip yet not synched. See attached image (showing audio clip after expanding).
