Activity Forums Adobe After Effects Lingering Particles
  • Lingering Particles
    Posted by Derek Natzke on November 7, 2008 at 2:48 pm
    I am trying to generate a “dust looking” particle that doesn’t “birth” but still has subtle life/movement to it. I want pieces in the foreground to be larger than the background. Something that will give depth. I would like to move a camera through it. I can’t afford to get a Trapcode pug-in. Are there filters that will achieve what I am looking for “stock” in AE CS3? I have been messing with CC Ball Action…
    Thank you,
    Derek
    Derek L. Natzke
    Producer, Life Studios
    http://www.lifeteen.com
    602.840.1900
    David Bogie replied 17 years, 9 months ago 3 Members · 2 Replies
  • Paul Conigliaro
    November 7, 2008 at 3:49 pm
    I would play with CC Particle World, which responds to camera movements. Use faded spheres for the particle type, up the XYZ radius, gravity to 0, resistance up a bit. Change animation to Twirly. Just play with it. You’ll find something you’ll like.
    Just have the life of the particles long (30 seconds or however long your comp is plus a few more), and have a high birth rate for a few seconds, then set it to 0. If you shift your layer so these keyframes are before the comp starts, you have particles that just exist and will linger for a while.
  • David Bogie
    November 7, 2008 at 4:05 pm
    also suggest you stop by the Cycore site and download the Particle World tutorials. Very difficult to get your head around this stuff and I can’t really tell from the post what you’re after.
    PW has tons of hidden properties and settings. For instance, you can get to a floor property that is accessible form the OPTIONS. You can set it to be sticky, bouncy, or to behave like ice.
    And, known to but a few, you can set z-space positions for the emitter to make it go behind the layer to which you are applying the effect/ That is, if you have a logo on an alpha, you can apply PW to it and have the emitter trace a spiral in front of and behind the layer. Aitn’ easy nor direct but it can be done.
    Anyway, using the Ice or Glue Floor options you can have a spray of particles come toward the camera and stay put.
    Gotcha: You cannot apply PW twice to the same layer. Only one will show up.
    bogiesan
