lines in fast motion video..please
Posted by Marvin Tackie on June 6, 2010 at 12:20 amPlease help guys asap! I have a project of a video that the customers need tonight…I burned the final edition..and I have these lines…I think from the interlace or whatever…only thing is I don’t really understand..or know the settings to make them go away…
please help
I am using sony vegas 9 pro
shot in 16:9…with sony fx7
720×480
project settings are wide screen
deinterlace – blend ?? (hope thats right)pixel ratio – 8
rendering best quality 2 pass..with mpg2
thanks in advance
John Rofrano replied 16 years, 4 months ago 2 Members · 5 Replies -
John Rofrano
June 6, 2010 at 11:43 amYup, it sounds like you have an interlacing problem which is usually caused by an incorrect interlace setting somewhere in your workflow. For a Sony FX7 you should be using the following templates:
Project: HDV 1080-60i (1440×1080, 29.970 fps)
Render:
Video: MPEG2 – DVD Architect NTSC Widescreen video stream
Audio: Digital Dolby AC-3 Pro – Stereo DVDCheck that this is what you used. Don’t change any of the defaults.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Marvin Tackie
June 6, 2010 at 1:20 pmthank you John for your reply…the problem is I borrowed the camera..didn’t realize that it was not shot in HD..but rather DV. Thats what I think anyway…because when it captured..it would only capture thru DV…not HD. The DV tape plays on my Sony pd170 so I think it was DV. (The mini dv tape I bought said HDV/DV)
The project settings I used were:
NTSC DV Widescreen (720×480, 29.970 fps)
720×480
I am so confused about the interlace thing…originally it was set to none..and I later I changed it to blend.
I have been reading the forum for days trying to figure out the correct answer..as I was supposed to have this video for the customer days ago.
I again delayed them..and promised to have it today….
Thanks in advance..you guys are great! I have learned so much!!
John please tell me there is something I can do….
Do I take the rendered avi file and change the properties to what you listed ?? or Take the veg work file …and change the properties and Render like that ?? Being it was not shot in HDV ??
thanks again ..I really appreciate this!
John Rofrano
June 6, 2010 at 2:39 pmI am so confused about the interlace thing…originally it was set to none..and I later I changed it to blend.
Never set interlacing to none. Especially when working with interlaced footage.
Why did you render an AVI file? You should be rendering to MPEG2.
You should go back to the project .veg file. Make sure that you select the NTSC DV Widescreen (720×480, 29.970 fps) project template and that Deinterlace method is set to Blend fields. Then render with the MPEG2 and AC3 templates in my previous post. Those files will drop right into DVD Architect.
~jr
Marvin Tackie
June 6, 2010 at 6:24 pmGreetings..thanks for the info John….I always render to Avi at 1st…then to mpg2 b4 puttin on dvd….
I render to avi 1st..for everything ..b4 converting to another format..is this correct ??
thanks again
ps…I’m assuming I should leave the fields default correct ?
John Rofrano
June 7, 2010 at 2:28 amI render to avi 1st..for everything ..b4 converting to another format..is this correct ??
It depends. If you shoot HDV your video is using 4:2:0 color sampling. DVD MPEG2 also uses 4:2:0 color sampling. DV AVI, however, only uses 4:1:0 color sampling. So if you render to DV AVI first, and then DVD MPEG2, you are throwing away color information that could have made your video look better. If, however, you are shooting DV in the first place, then it’s perfectly fine to render to DV but even then, each render looses some information so going directly to MPEG2 from the timeline will always give you better quality than rendering twice.
Yes. Leave the field order as is.
~jr
