Activity Forums Adobe After Effects Lines and rounded corners
  • Lines and rounded corners
    Posted by Johannes Schwarz on April 13, 2009 at 1:08 pm
    Hi everyone,
    I try to create moving lines, and would like them to go around a smooth 90 degree bend with rounded corners much like in this commercial example:
    https://www.revostock.com/FileCloseupAE.html?ID=74739
    Is there an easy way to do this in AE directly without AI or PS. I get my moving line (stroke effect) but the round corners are eluding me
    Well, naturally I could buy the project, but I’m rather on the poor side of things, so if anyone has a quick tip it is much appreciated.
    Johannes
    Jan Sherlink replied 17 years, 5 months ago 3 Members · 4 Replies
  • Curious Turtle
    April 13, 2009 at 1:40 pm
    Yes. When drawing your lines with the Pen tool, turn off “Rotobezier” and use the shift key to create straight lines. If you create a control point where you want your corner to start then click-drag where you want your corner to end, you can create a nice rounded corner.
    If you don’t get it at first, then practice. It’s pretty straightforward.
    Good luck with your project,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Just out: Rock Steady : Successful Motion Tracking in Mocha & After Effects
  • Johannes Schwarz
    April 13, 2009 at 2:06 pm
    Thanks a bunch Ben
    At first, I didn’t quite get it, but alas now I understand your pointer and it works. Hurray! Do the straight lines; create the start and end point for the curve; drag their handles to the corner point (of the straight line); delete the corner point.
    Thanks again,
    Johannes
  • Curious Turtle
    April 13, 2009 at 2:14 pm
    You could do it that way. Or just skip the corner point like this:
    Glad you’ve got it working, either way though.
    Ben
  • Jan Sherlink
    April 14, 2009 at 9:41 am
    You can also use Shape Layers.
    Draw your line-shape with 90 degree angles,
    Add: Rounded Corners
    Add: Trim Paths
    That saves a lot of handles and control points !
    cya,
    Jan
