Activity › Forums › Adobe InDesign › Lines
Lines
Posted by Stephen Takacs on July 8, 2009 at 10:28 amWanted to know if anyone could tell me how to add a line to a doc in Adobe Indesign CS4.
What I mean is if I am design a cover sheet to be fax for someone and i write the word date and then want to put a dark line next to it to write one how do I do this??/Stephen Takacs replied 17 years, 1 month ago 2 Members · 5 Replies -
Terry Mikkelsen
July 9, 2009 at 6:56 pmUse the tabs feature.
Type “date” and then press the tab key.
Now, goto the “Type>Tabs” menu
In the little box that appears, first click once above the number to set a tab position. Next, in the “Leader:” box type the character you wish to proceed your tab, in this case an underscore “_” and then press the tab key again. Now you can drag your tab position (the little arrow) along the ruler to set the length of your line.Tech-T Productions
http://www.technical-t.com -
Stephen Takacs
July 11, 2009 at 2:37 pmHello Tarry
Thank you for the help if I wanted to put a black line next to the word date how do I do that??? -
Terry Mikkelsen
July 12, 2009 at 2:18 amIt is still text. Highlight the section you want with your text tool and change the color to the black swatch.
Tech-T Productions
Stephen Takacs
July 12, 2009 at 1:18 pmHello Tarry
What I am design in Adobe Indesign is a cover letter for a fax and when I have words like Date one the cove letter i want to put a black line in front of the word so that when i print it the person can write on it. I did it once but for got how to
