Activity Forums Adobe After Effects Expressions linear wipe with stroke
  • linear wipe with stroke
    Posted by Guillaume Charron on August 7, 2009 at 5:43 pm
    Hi everybody!!
    My problem…
    I want to make a simple linear wipe… but with a stroke on the edge (without adding mask and/or another layer to make the stroke).
    I played around with the grid effect and the linear wipe effect. But the linear Wipe effect does not have a position control tool, it is a percentage. So, as you guest, I tried to link one to the other… and it’s not working. I have to, I think, translate the percentage into position.
    Can you help me?
    Thanks.
    Brie Clayton
    replied 1 year, 4 months ago
    5 Members · 4 Replies
  • Dan Ebberts
    August 7, 2009 at 6:25 pm
    How about using the beam effect with this expression for the beam’s Starting Point:
    pct = effect(“Linear Wipe”)(“Transition Completion”);
    x = width*pct/100;
    [x,0]
    And this for its Ending Point:
    x = width*pct/100;
    [x,height]
    You also need to set the beams length to 100%
    Dan
  • Filip Vandueren
    August 7, 2009 at 8:41 pm
    It gets a bit more difficult when you decide to rotate the angle or add softness etc.
    Here’s an alternative without expressions:
    -Linear Wipe
    -Solid Composite: Set the color to the color of your border, But Set Opacity to 50%
    – Minimax: Operation: Maximum, Radius: 8 (=border width), Channel=Alpha
    – Alpha Levels: Input Black Level=128
    Okay, now you can use the direction and even the feathering of the wipe to adjust the feathering of the border.
    Also these 3 effects work together after any wipe, so you can use this to add a border to an iris wipe, a radial wipe, or even an animated mask. Basically everything that alters the alpha of the layer get’s a border. So this won’t work well on footage that allready has an alpha.
    Come to think of it, you can achieve a very similar effect by just adding a Layer Styles -> Stroke, only without it responding to the feather.
  • Manuel Lino
    April 27, 2025 at 2:01 pm
    As Filip Vandueren recomended, adding a Layer Styles -> Stroke worked out perfectly for me!
  • Brie Clayton
    April 27, 2025 at 2:03 pm
    Thanks for the solve, Filip!
