Activity › Forums › Adobe Premiere Pro › Linear wipe with a border?
  • Linear wipe with a border?
    Posted by Michael Levin on August 15, 2011 at 12:37 am
    Hi guys,
    I was wondering what would be the best way to add a border or solid bar to the linear wipe effect? As in it works exactly like the linear wipe in premiere pro effects expect there is a bar moving at the start of the wipe clearly defining the areas before and after the effect.
    Any advice is appreciated!
    Michael Levin replied 15 years, 1 month ago 3 Members · 3 Replies
  • Ben G unguren
    August 15, 2011 at 3:56 am
    I’m not at my editing station at the moment, but I believe the wipe transition has an option to show a border already built-in. You just have to check the box and define the thickness & color….
  • Kevin Monahan
    August 15, 2011 at 6:33 pm
    Right, border width and border color can be changed. Good luck!
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Michael Levin
    August 16, 2011 at 6:45 am
    Thank you guys, I realised that I was using the “linear wipe” transition in the effects panel which doesn’t actually allow you to set a border but when using the “wipe” transition, both border width and colour can be set. Exactly what I was looking for!
    Thanks again!
