Activity › Forums › Adobe After Effects › Linear Wipe
  • Linear Wipe
    Posted by Conor Dalrymple on September 7, 2010 at 8:15 pm
    Ok ill try explain what I want to do here. I want to make a linear wipe sit at 50% transition, lock at 50% ( half way down the stage) then I simply want to move objects position below the wipe and the wipe will stay at 50. whenever i put a liniear wipe on an object it moves with the object I dont want it to! hope someone understands this jibber. thanks
    Todd Kopriva replied 16 years ago 2 Members · 1 Reply
  • Todd Kopriva
    September 8, 2010 at 6:15 am
    You could put the wipe and the object that you want to move on different layers.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
