Activity Forums Adobe After Effects Linear stroke gradient along shape path linked to 3D nulls
  • Linear stroke gradient along shape path linked to 3D nulls
    Posted by Adam C. Sager on March 10, 2025 at 3:22 pm
    I used the Create Nulls from Path script to generate a shape path that is linked to ~10 3D nulls. These nulls are distributed in 3D space so the path moves in perspective with a 3D camera tracked to footage (using taper to simulate a depth cue). I’m trying to get a linear gradient running from end to end of my shape/path, but I believe the dynamic link between the path points and the nulls is breaking normal functionality of the Gradient Stroke within the shape.
    I’m hopeful there is a way for a linear gradient to follow along all ~10 points of the path, but everything I’ve tried thus far hasn’t worked.
    Would greatly value any ideas, tips or tricks the Creative Cow community may have.
    Graham Quince replied 1 year, 6 months ago 2 Members · 1 Reply
  • Graham Quince
    March 11, 2025 at 9:06 am
    You’re applying what is in essence a 2D effect to a 3D shape. I think the closest you can do is link the null’s positions to the gradient points.
    An expression like this would help:
    thisComp.layer("Null 1").toComp([0,0,0]);
    The other option would be to make your gradient a precomp and make 3D, then use your 3D shape as a track matte for it. I did something similar in my Phaser tutorial a while back:
    https://www.youtube.com/watch?v=3Kp04bxpnmo
