Activity Forums Adobe After Effects Expressions Linear play hold play
  • Linear play hold play
    Posted by Ilya Sire on January 26, 2017 at 6:56 pm
    Hi forum,
    I have a linear on Rotation using linear(time,inPoint,10,0,360);
    How can i add hold for few frames (eg 3 frames) at random time (in duration inpoint to 10) and resume play and again..?
    I have been searching but no luck
    Any help.
    Sergej Mag replied 9 years, 6 months ago 3 Members · 4 Replies
  • Dan Ebberts
    January 26, 2017 at 7:30 pm
    Something like this might work:
    hDur = 3; // hold frames;
    h = framesToTime(hDur);
    seedRandom(index,true);
    hStart = random(inPoint,10-h);
    if (time < hStart)
    else if (time < hStart+h)
    linear(hStart,inPoint,10,0,360)
    else
    linear(time-h,inPoint,10,0,360)
    Dan
  • Ilya Sire
    January 27, 2017 at 6:45 am
    Thank you for your response Dan,
    it work only one pause, but how to pause multiple time like play, stop, resume play, stop again.
  • Ilya Sire
    January 28, 2017 at 7:25 am
    i found this similar from your previous reply in case random pulsing, can it applied to this case?
    Please help. ☺
    Ilya
    minHold = 24; // min hold frames
    maxHold = 40; // max hold frames
    fade = 12; // fade frames
    t = t0 = 0;
    hold1 = minHold;
    f = fade*thisComp.frameDuration;
    while (t &lt;= time){
    hold1 = Math.round(random(minHold,maxHold))*thisComp.frameDuration;
    hold2 = Math.round(random(minHold,maxHold))*thisComp.frameDuration;
    t0 = t;
    t += f*2 + hold1 + hold2;
    t1 = t0 + f;
    t2 = t1 + hold1;
    t3 = t2 + f;
    if (time &lt; t1)
    linear(time,t0,t1,0,100)
    else if (time &lt; t2)
    100
    else if (time &lt; t3)
    linear(time,t2,t3,100,0)
    else
    0;
  • Sergej Mag
    February 20, 2017 at 7:54 pm
    I had a similar situation. I had to repeat the movement and the occasional long pauses. Maybe my expression is useful to you.
    and see more random rotation with accumulating loop
    Sorry for my English!
    segMin = 2.5; //minimum segment duration sec
    segMax = 5; //maximum segment duration sec
    runDur = 1.5; // run duration
    oldPos = 2380; // x position start
    newPos = -500; // x position end
    yPos = 0; // y position
    end = 0;
    j = 0;
    while ( time >= end){
    j += 1;
    seedRandom(j,true);
    start = end;
    end += random(segMin,segMax);
    if (time > end - runDur)
    seedRandom(j,true);
    y = random(0,1080);
    linear(time,end-runDur,end,[oldPos,y],[newPos,y])
    }else{
    seedRandom(j,true);
    y = random(0,1080);
    [newPos, yPos+y]
    // random rotation with accumulating loop
    j = 0; //initialize loop counter
    accum = 0; //initialize random accumulator
    while (j < time){ accum += random(10); j += thisComp.frameDuration; } rotation + accum
